high bitrate fix for ci+ cam modules(max tv croatia)
shilev
Is there any chance for making possible CI high bitrate in BH image? I heard that max tv ci+ cam is working great in vu+ ultimo and vu+ uno. But in vu+ solo2 it's working only in openpli image with high bitrate fix file. I was hoping for fix in 2.0.5 version but i don't see it in describings of new image.
I'm very close to buying vu+ solo2, and i would be really happy if max tv croatia could be possible to watch in the best image - BH! :)
Sent from my Nexus 7 using Tapatalk HD
Actually the "plus" part of CI+ CAMs it's not supported.
Write directly to Vu+ about that.
Yes,i know that ci+ is not supported. But problems is not this, because many recievers that doesn't support ci+ actually can read this ci+ cam (dm7020hd,dm8000....). The strangest part is that vu+ ultimo and vu+ uno also read this card, on bh image! Bh 2.0.1 on uno,and don't know which on ultimo. so it's not problem in ci+, but in high bitrate support or something. I'm not an expert. Also, as i wrote, this cam works in vu+solo2 in open pli, with high bitrate fix.
http://www.vuplus-community.net/board/index.php?posts/101804
So, i guess it could work also in bh image..
I doubt that i's general vu plus problem. It works on ultimo and uno in bh, and in solo and solo2 in openpli with high bitrate fix.pretty strange, isn't it?
Thanks for explanation. So drivers in uno and ultimo are ok,and in solo and solo2 not?
Read also the original thread @ Pli board and you will be more explanations-
It is a driver issue. You should write to Vu+, we cannot fix drivers.
Maybe you are lucky and VU+ fix your issue!
http://www.vuplus-community.net/board/threads/update-drivers.13595/
Please update drivers and confirm here if it is fixed?
