Request Hour Problem BH 2.0.3
romg34
Hello to every one !
I have a problem with my Vu+ solo running on BH 2.0.3, i have 3 hours difference from the true, i checked the Time zone, ok.
Try to reflash my box, same problem. The EPG loaded is also with 3 hours difference !
So my question, can i set the hour manually ?
Thanks a lot !
Thanks a lot !
Time and date are taken from Transponder you tune.
You can adjust timezone into box.
Thanks for your answer, but already done, the time zone is ok, an the problem stay here :)
I have exactly 2h34 less that the true to be correct.
