How can I access VU+ Uno via RS 232 serial port?
Giorgos
Hi,
Anyone who can guide me how to access my newly VU+UNO via the RS 232 port and what kind of an emulator do I need to use please?
Best Regards,
Giorgos
Hi,
Best Regards,
Giorgos
Your question is not clear .... Putty and a null-modem cable are sufficient ....
Hi,
Thanks. I manage to attached my RS232 cable and I can now see what is coming out of the RS interface.
The speed of the Hyper Terminal was the issue.. but when I set it to 115200 and with a VT100 emulation, this did the trick.
Kind Regards,
Giorgos.
Hi,
Kind Regards,
Giorgos.
so what could you do, using the rs232 ?
can you start a console using the rs232 ?
