How do I configure Solo2's Tuner A&B with 2 LNBs and a motor?
Giorgos
Hi,
I have a Solo2 with the following connection and configuration:
SOLO2 Connection:
1. My connection from Solo2, LNB1, goes to motor and then to LNB port 1 on the dish (motorised LNB port1)
2. My connection from Solo2, LNB2, goes directly to LNB port 2 on the dish.
My Tuner configuration is as follows:
1. Tuner A: Positioner: USALS
2. Tuner B: Second cable of motorized LNB Tuner A:
With the above connections and setup I can tune to any satellite using Tuner A only.
Can anyone help and/or advice how I can configure the two Tuners so that I can watch a channel from Tuner A and record from Tuner B?
As before, your help will greatly appreciated.
Kind Regards,
Giorgos
Hi,
SOLO2 Connection:
Kind Regards,
Giorgos
Setup should be correct.
About tuning, you can tune with A and start record with that tuner and see another DVB service from the same satellite with tuner B.
