Do you want to have a transparent meny so you can see the playing channel in the background or do you want the skin in it selv to be transparent?
If you want to make the whole skin transparent you can do that under AV and Video Settings but that only works for skins that have "Picture In Graphic"
If the skin have a small mini TV screen when you scroll through the menu system or your channel list then it want work.
