how do I record a radio channel with Blackhole?
a19a
Hi,
I want to record radio channels with the Blackhole image.
Could you please tell me how to do that?
thanks,
a19a
Hi,
thanks,
a19a
It might be the same as TV channel, I well verify that when am at home!
Yes it can be done,,,when U @radio mode,,,the same as @TV mode!
Press Radio button @RC>>Press Red button @Bottom of RC,,,a list will show up,,,,etc!
Greetings to all.
I have installed 2.0.9 on vu+ uno, however I cannot find a way to record a radio channel using the steps above.
When I switch to "radio" mode, I am stuck with the list of channels. Almost no remotekeys work , except for "exit" which takes me back to tv mode, "menu" which gives me options on the specified channel in the list and "EPG". No record button functions, no way to access the timer actions. Similar, I cannot use timer for radio channels on my webif interface. Pressing timer on webif gives a pool of channels limited to my TV favorites.
Is there a way I am missing to record an audio channel?
The only bypass I've found, is to put the desired radio channel in the list of tv favorites and record as such. But surely there should be a "normal" way...
Thanks in advance.
Greetings to all.
Thanks in advance.
First change in the System Menu >> Customize (Setup Mode expert)
Alternative radio mode> Yes and SAVE
The Duo2 does not record for me either. Alternative radio mode is set to yes.
A radio recording is saved to my hard drive but nothing is on it and it will not play. No information is stored in the recording.
Also, AAC audio does not work for me in radio mode.
