how do you clear data from xbmc on vu solo2
joiner
hi all, as the title says, could somebody please tell how i can clear all data from xbmc on my vu solo 2 please. thank you
Your Xbmc data must be on the root of your /media/hdd ... with an ftp tool ( dreambox control center or filezilla or winscp ), navigate to /media/hdd and there you´ll find as /media/hdd/.xmbc , so delete the folder /.xbmc .
Proceeding with this your XBMC will return to virgin state!
nunigaia, sorry for late reply. tbh im not sure if it did, i am trying to install wookie but it will not load correctly . for a successfull install you need to clear all data from xbmc. so as it has not installed correctly im not sure if it has. once instalation is complete i get the message skin scripts not working. i did notice that the xbmc folder takes a long time to delete files. thank you very much for your help though, and if you have any further thoughts i would appreciate any ideas. thanks and sorry again, joiner.
