Request How i can add a streaming channels?
moh010
I would like to know how can i add a streaming channels like to one that you can watch throw the computer to Stream TV Plugin on my Uno
The links starts with mms:// or rtmp://
My receiver is Vu+ uno and the image is blackhole 1.7.6
Many thanks
Moho10,
Open DCC (DreamboxControleCentre) and connect to your box,than, on the richt dropbox you see your pc content and in the left dropbox you see the VU content
open FTP commander/usr/enigma2/python/plugins/extensions/streamTV
and there you will see a map called "stream.xml" and in there you can add/remove stream adresses.
Good luck and don't make mistakes, 1 digit wrong and you have a "green screen" so take care and make back-up 1st.
V8
Thanks very mush I'm trying to do it however allows a green screen if i add any address i think i just can't do it
Regards
Moh010
