How I supposed to use the channel feeds? satellites 13.0e + 28.2e
boyofford
Morning all!
Don't think I am using the channel feeds settings correctly.
I have two satellites 13.0e and 28.2e which I'm running through a diseqc into one of the tuners on my Solo2. I scanned the satellites and got all ones on 28.2e and 13.0e that I want working in main list.
So then wanted to setup bouquets.
I installed Vhannibal Quadri 13,19,23,28e via the options in the blackhole image as it was the only option with 13e and 28.2e(I figured I could just remove the ones I didn't want).
All channels on 13.0e in bouquets were correct but when I tried the channels on the 28.2e satellite via bouquets it says I've got a tuner config problem.
Strange thing is can still view channels through main satellite channel listings. When I connect via dreamboxedit says I've got 28.2 satellite and the other 3 on feed are grouped under some random characters.
I Might figure this out myself, but thought I'd ask as ain't been able to figure out via searching.
Cheers
Morning all!
Cheers
How did you configure your tunner?
I think it should be... Mode>Simple & A/B/C/D ...and then Select A for either 13e or 28.2e depending on the feed, then set up B for the other sat, then C&D should be 'not connected'
Hope it helps mate.
Sent from my GT-I9100 using Tapatalk 2
Hi,
I've got it set up with a diseqc switch connected to tuner b. Think set as simple a/b diseqc. Will eventually use both tuners but diseqc switch is outside and need more cable so will sort this later. It scans transponders on both satellites and channels are watchable off both. Problem is the ones in bouquets don't seem to link to channels scanned for 28.2.
I'll have a look at that setting, may have to connect both tuners sooner rather than later then.
Gona try another bouquet set I've found and DBE it onto box and rescan transponders I think. Maybe reflash first too.
Thanks mate
Hi,
Thanks mate
First download ready list
and scan only if necessary.
Otherwise use dreamboxedit to FTP list/settings
Well sort of got there using both your help! but now I don't like the was set up and some channels don't work for some reason though do in a backup I've got!
What I'm thinking of doing now is creating a satellite xml with sat info for 13.0e from one downloaded bouquet and sat info from 28.0e from other then scanning again.
then using dreamboxedit I'm planning to import the bouquets I want from both bouquet sets. Reason I'm not just downloading most up-to-date satellite xml if that importing channels doesn't seem to work when did this before if memory serves me right this. Anyhow can't find much on web of anyone doing similar so wish me luck LOL.
