How mount my HDD in open multiboot Black Hole
guruamba
I have IMG BlackHole 3.1.0 in open multiboot. But i can't connect my HDD to media / HDD. It is in omb format or something similar and by initiating it I would lose all the data stored on the HDD.
Yes, this was an historical problem of previous versions of BH if installed in flash, but I supposed it had been solved: it automatically detects the /media/hdd to watch already recorded files but it was unable to use for new recordings because it cannot succeed to mount it.
It seemed to succeed but, after the restart, everything was as before...
I can't check it now (I, too, have BH 3.1.0 in OMB): is it still the same? It seems so, from your post.
Yes, it's the same. Black Hole in flash has HDD connected to order media / hdd. The HDD is not connected in open multiboot, it cannot be played or recorded.
Well, actually, if I remember well, the play was possible: pressing the REC LIST key, it correctly showed the recordings. Only, I couldn't record any new one from OMB.
