How Remove Satellite in Mac
recteur
Hi , i have Duo2 with BH inside , i have mac abd i used iDereamx3 ,need help to edit sat list ,i download file satellites.xml ,i put it in etc/tuxbox/ ,but. the old sat dont remove and some sat with unknow name..wich step i need to do to added new channel and remove old sat ?
Thx for help.
Thx for help.
Have you rebooted your box after put the new file?
Not working when i click on green button to show the sat i have not the sat i download from satelites-xml generator.. How i can remove all sat availble in the box , and start from the begning ,or put bouquet without satellites ?
