How to add stream to ip*v
bluearmy123
Hi I have got some streams I want to add to my favourites in my iptv list if anybody could tell me how to do it Please? i don't no how to do it. because I have updated my iptv list but can't find the be*n sports streams if they are there can somebody tell my where I can find them if they are there?
Thanks....
Thanks....
what box have you got ? I assume its a vu with blackhole but it may not be . with a vu using blackhole you have a few methods , I mentioned one method in my last post in the tsmedia plugin thread which involves using tsmedia to play the links , I use this method my self and it works well .
another method is to use media player in the vu , to use that you edit a playlist file .
a third method is to add links to the favourites bouquet .
all 3 methods require you to use either dream control center or vu control center to either edit or create files . personally I find using tsmedia better and quicker , its better because you can view all most all iptv links using tsmedia where as using the favourites bouquet limits you a bit . also using tsmedia makes adding links to m3u files a bit easier , there is a format to add the links and with tsmedia its straight forward but a little more difficult and a little more work with the other two methods .
just to add if you get tsmedia plugin working , you can use navi extreme plugin , that has lots of sports iptv . and the good thing is with ttsmedia you have the option to add any of these channels to a bouquet . so you can add all the channels you want to a bouquet (which is called tsmedia by default as tsmedia creates it automatically ) and once you have added all the channels you want too the bouquet reboot the box or restart enigma . then access your boquets as normal and you should see a tsmedia bouquet in there , open it and select a channel .
