HOW TO ADD THE vu uno tunner supports DVB-S2 multistream
dxerwong
andytvro
Multistream supported for all STV0903BAC, STV0900BAC, STV0900AAB/AAC devices, which use stv090x demod driver. In current V4L-sources this is TBS6925, 6992, TBS5980 and another devices like Techisat SkyStar HD USB, Omicom S2 PCI (with my patch to budget.c, included)
So - unpack my archive to dir with linux-tbs-drivers, run patch.sh. Next build as described in README from linux-tbs-drivers.
Next unpack and build modified scan-s2, szap-s2. Maybe someone make patches for popolar linux DTV-soft like VDR. And submit my patches to V4L maintainer.
P.S. Some transponder info for scan-s2 with well-known multistreams on 31.5E:
SELECT ALLS2 11914000 H 27500000 AUTO AUTO 8PSK 2
S2 11914000 H 27500000 AUTO AUTO 8PSK 3
S2 11914000 H 27500000 AUTO AUTO 8PSK 4
S2 11914000 H 27500000 AUTO AUTO 8PSK 5
S2 11993000 H 27500000 AUTO AUTO 8PSK 10
S2 11993000 H 27500000 AUTO AUTO 8PSK 20
S2 12148000 H 27500000 AUTO AUTO 8PSK 30
S2 12148000 H 27500000 AUTO AUTO 8PSK 40
And 12.5W:
CODE:
SELECT ALLS2 12718000 H 36510000 AUTO AUTO 8PSK 33
S2 12718000 H 36510000 AUTO AUTO 8PSK 34
S2 12718000 H 36510000 AUTO AUTO 8PSK 35
S2 12718000 H 36510000 AUTO AUTO 8PSK 36
crazycat
on Fri Nov 09, 2012 2:29 am, edited 3 times in total.
andytvro
the link
http://www.tbsdtv.com/forum/viewtopic.php?f=26&t=1874
EDITED BY ADMIN, DO NOT PUT LIVE LINKS ON THE BOARD PLEASE.
angelofsky1980
BlackHole Driver Specialist
Actually TBS devices uses some open source drivers mixed with closed source object and it's impossible to implement it into VU+ STBs.
About Technisat skystar HD USB it's very interesting thing: I hope this device have a lowest price ... and I will try it with multistream.
Burley
Any results with multistream and have you tested to get Technisat usb 2 hd working on
a VU+?
Because in my case it won t recognized...is there any known driver issue ?
angelofsky1980
a VU+?
I haven't Skystar HD USB actually but it's in my whislist ...
Burley
Btw,Technisat will end pc-dvb-products support & production!
So it can be,that shops are only sale their last stocks!
angelofsky1980
Is it possible to use the USB TBS 5925 with Duo2 and BH 2.0.6b ?
Are there some drivers ?
I've looked inside Linux driver released by manufacturer but the answer is NO because they don't provide a full open source solution.
I've seen another post with some full open source driver .... I'll investigate with them
sperl59
Thanks, it could be interesting if it works..
angelofsky1980
Uhm .... I've found some source files about TBS device included 5925 ...
If you have that device you can test it using the ATSC alpha BH image, issue Online Updates and next try to use your device.
