HOW TO ADD THE vu uno tunner supports DVB-S2 multistream
andytvro
at the 88E KU BAND 11633H 30000 dvbs2 8p 3/4 .it is using the DVB-S2 multistream ,
the uno can blindscan the TP ,but can download the channel.
i find the supports in this web ,https://patchwork.kernel.org/patch/1309221/,how to get that patch in the vu uno. hlep me
Multistream supported for all STV0903BAC, STV0900BAC, STV0900AAB/AAC devices, which use stv090x demod driver. In current V4L-sources this is TBS6925, 6992, TBS5980 and another devices like Techisat SkyStar HD USB, Omicom S2 PCI (with my patch to budget.c, included)
So - unpack my archive to dir with linux-tbs-drivers, run patch.sh. Next build as described in README from linux-tbs-drivers.
Next unpack and build modified scan-s2, szap-s2. Maybe someone make patches for popolar linux DTV-soft like VDR. And submit my patches to V4L maintainer.
P.S. Some transponder info for scan-s2 with well-known multistreams on 31.5E:
SELECT ALLS2 11914000 H 27500000 AUTO AUTO 8PSK 2
S2 11914000 H 27500000 AUTO AUTO 8PSK 3
S2 11914000 H 27500000 AUTO AUTO 8PSK 4
S2 11914000 H 27500000 AUTO AUTO 8PSK 5
S2 11993000 H 27500000 AUTO AUTO 8PSK 10
S2 11993000 H 27500000 AUTO AUTO 8PSK 20
S2 12148000 H 27500000 AUTO AUTO 8PSK 30
S2 12148000 H 27500000 AUTO AUTO 8PSK 40
And 12.5W:
CODE:
SELECT ALLS2 12718000 H 36510000 AUTO AUTO 8PSK 33
S2 12718000 H 36510000 AUTO AUTO 8PSK 34
S2 12718000 H 36510000 AUTO AUTO 8PSK 35
S2 12718000 H 36510000 AUTO AUTO 8PSK 36
crazycat
on Fri Nov 09, 2012 2:29 am, edited 3 times in total.
the link :http://www.tbsdtv.com/forum/viewtopic.php?f=26&t=1874
