how to add to favourites list on vu+duo with blackhole
ian valentine
hi all just got my vu duo up and working ok was just wondering how to add to favorites list,any help would be gratefull as im a newbe to all of this so any info with snap shots etc showing how to to this would be great and how do you remove channels as well thanks all
Do U have already a favorites list.....or U"r going 2make one.....:confused:!
If U do,,,its easy!
1- While U'r @ channel list (All) press menu! button.
2- A list will show,,,,,chose "Add service 2 bouquet" and press OK.
3- A bouquet list will show with named favorite..chose what location 2be added too..press OK!
4- Now the channel chosen @step 2 is added 2 U'r favorite!
Rmoving a channel is almost the same , however on step 1 U open the list of favorite channel
5- Chose remove entry,,,press ok,,,channel is gone from the list
If U do not have a favorite list,,,,thats another story!
RgdZ
a911
hi if you could give me the info on how to make a favorite list i would be most gratefull as hate having to search via all of 28.2 plus any info on setting up motor dish as well we have it all set up but have tuned in 13e as well channels but when we go to change channel from 28.2 to one on 13e the dish will not move thanks once again for any help you have given
The easiest way to do it is using DreamBoxEdit on a PC. Download your settings from the Duo (or use a new settings file), create your Favorites, then upload to the Duo.
download catseye settings off server that is a good channel list which you can then edit
favourite list careit in DCC ???
Is using a settings editor ... like @sonc said here http://www.vuplus-community.net/boa...ist-on-vu-duo-with-blackhole.4058/#post-33849 , or dreamset ( also a settings editor tool ), for enigma2 STB´s.
For dreamboxedit --> http://www.vuplus-community.net/board/threads/dreamboxedit.18975/#post-206659
For dreamset --------> http://www.vuplus-community.net/board/threads/dreamset-32-e-64-bit.3595/#post-198937
