As I wrote, the file named
settings
contains some lines starting with the string "NIMS......"
OK. Thanks! I get it now. In the file "settings" I found the following lines that apparently relates to rotor position numbers:
config.Nims.0.powerMeasurement=false
config.Nims.0.advanced.sats=130
config.Nims.0.advanced.sat.130.rotorposition=3
config.Nims.0.advanced.sat.130.usals=false
config.Nims.0.advanced.sat.130.lnb=1
config.Nims.0.advanced.sat.192.usals=false
config.Nims.0.advanced.sat.192.lnb=1
config.Nims.0.advanced.sat.160.rotorposition=2
config.Nims.0.advanced.sat.160.usals=false
config.Nims.0.advanced.sat.160.lnb=1
config.Nims.0.advanced.lnb.1.latitude=36.0
config.Nims.0.advanced.lnb.1.diseqcMode=1_2
config.Nims.0.advanced.lnb.1.powerMeasurement=false
config.Nims.0.advanced.lnb.1.longitude=25.0
config.Nims.0.configMode=advanced
But they do not contain information of the dish (parabolic antenna) direction for each position. Where would the data for the DiSEqC 1.2 motor position command in order to point in the direction that I have set up for each satellite? It is time consuming to optimize the antenna direction, so I would find it very helpful to be able to backup the directions (motor positions) too.
