hi I have vu solo2 does any one no how to change the aspect ratio for uploaded or streamed movies as they are stretched to fit screen. I have been into av settings and tried changing all that's available but does nothing. thanks kevin.
hi thanks for both replies tried all them yesterday they did not work but for some reason it worked today. thanksTry to use the Aspect Ratio Plug-in, from BH add-on menu.
I can't find this plugin from addons menu... :-(Try to use the Aspect Ratio Plug-in, from BH add-on menu.
Menu/Addons/Addons Download Manager/Blackhole feeds pluginsI can't find this plugin from addons menu... :-(
