How to change epg color in tv bouquets?
Mohammedabdu
I have the latest image of black hole 3.0.9.C & I'm using default skin, inside the TV Bouquet the channel name & the channel epg are beside each other & they've the Same colors (white) &I can't differentiate between them, I'm asking if there's a way or plugin to change the colors of the channels name for example ( blue) or change epg color so I can differentiate between them ?
