How to change VFB Display info?
mrkrabs
Hi guys,
Is there an easy way to change the VFD display info on BH 1.7..9.3? Rather annoyingly my display appears to show the last menu I was in and I'm not sure where I can change this. I'd like it just to show the name of the channel again. Pretty sure it was defaulting to this at the beginning and I have no idea how I changed it! Thank you!
AGN
You have install LCD PICONS ???
REMOVE/delete LCD PICONs
\usr\share\enigma2\piconlcd\
REMOVE/delete skin_user.xml
from
/etc/enigma2
Restart BOX
Thanks a million for this. I'd the same issue for last couple of days and your instructions worked like a charm!
Thanks again!
