http://ip2your.stb.com/lcd4linux/view
http://ip2your.stb.com/lcd4linux/config?Mode=1
He said he has a "small TV"...NO USB needed
Indeed I just anticipated the need for "a compatible display" as Alfred42 didn't specify what small TV he has, but most likely it wouldn't be a tablet nor even a small "smart TV" (it'd be a waste of money to use a smart TV as a display of some info data).What "small TV" is compatible then
https://ssl.bulix.org/projects/lcd4linux/wiki/Displays
how can i use my samsung note 10.1?NO USB needed
Use your tablet IOS/andriod whatever
Code:http://ip2your.stb.com/lcd4linux/view
about +2 displays and config take a look at
(instead of using plugin to config)
Code:http://ip2your.stb.com/lcd4linux/config?Mode=1
