how to create different channel lists using universes
justbekind
i have BH 1.7.1 installed now i can get channel list backup using dreambox edit
i want to install BH 2.0.1 OE 2
i want to have different channel list in universes
i am a bit confused about how should i do that would u pls describe the procedure step by step
By DreamboxEdit, you can modify your settings and create different settings packages.
Therefore, first install the new image and upload your settings.
Then enter into another universe and upload other settings.
thank u for ur prompt reply and sorry for the delay from my side
then u mean:
first i can upload channel list in black hole which as far as i know it will be send to other universes automatically
second i create different channel list by using Dreambox Edit in other directories
third load these new lists and send them in the related universes
and the list in the first step will be overwritten is that right?
then u mean:
Read here: http://www.vuplus-community.net/boa...olo-1-7-4-parallel-universes.6536/#post-52809 to understand universes ;).
i have already read that and have got the general understanding of the universes
i asked just a simple question
is what i said right or not?
