Request How to Disable Audio Narration Permanently?
cgj97
This is driving me crazy - Can anyone please tell me how I can disable the Audio Narration permanently for all channels in BH1.7.2 image?
Thanking you in advance!!
You have to change each channel manually (yellow button then select the other audio track and press ok).
Or if you go into menu/setup/system/av settings and select AC3 default, then that should sort it for 90% of channels for you.
If that still doesn't work well enough for what you want.
Reflash your box with Black Pole and use the intergrated Auto Language option :)
