As long as you have everything installed correctly, when watching a movie press your OK button on the remote or similar button and the bottom menu will display. Go to the right where you see a sort of television icon with ...... inside. Press ok on that and make sure subtitle is enabled, then press download and it will display a list of available subtitles to use. Choose the one you need
