How To Edit Channel Frequency.?
Nurspec
How can i edit the frequency of a single channel manually without editing every channel on the same transponder..?
I can only find the option for Transponder edit using DBE, is there a way to do it through the box settings, or does anyone know how to do it using DBE or other S/W..?
Thanks
Why would you want to?
You can scan in the channels twice, on different frequencies, then delete the ones you don't want, using dreamboxedit, and FTP them back to your receiver.
1: Why would I want to?...... ( Because if only one channel changes frequency on a transponder, then I would like to be able to edit it's frequency, without changing multiple channels, and editing the subsequent Picons , which takes ages! :(
2: I know I can manually scan the channels and replace them in the Bouquet, but I refer you to answer 1, it means multiple edit of the picons?
