How to enlarge OSD (epg info etc.)
Dannermax
Hello.
I have Blackhole installed on my VU+2 DUO. A can't figure out how i make the OSD size, bigger. When i look at the epg, i have to stand really close to the TV in order to read the text.
I have googled some screenshots of Blackhole, and i can see on these images that the OSD can be much bigger.. but how do i do this?
Cross my fingers!
Thanks
Hello
If you go to your epg and press either 1 or 3 on your remote that will change the epg to every half hour, every hour etc
I hope this is what you are looking for
Hello
Thanks for the reply.
No it wasnt what i ment. I mean the physical size of the menus..i want to make it physical larger.. So it takes up more space on the tv...hope it makes sence.. :)
