How to flash UNO
Hi
downloaded latest bh, can someone please tell me how to flash the box please
vf
How to upgrade the Vu+ BH image via USB
1-Save the image on the PC (USB version)
2-Unzip files (U can unzip directly to USB and skip steps 4 & 5)
3-Format USB flash drive with the file system FAT,or FAT32
4-Create on the stick : Directory/vuplus/duo
5-Copy to the stick the 3 files into Directory/vuplus/duo
6-Power off VU+ STB
7-Remove all USB devices from the box
8-Plug-in the USB Stick into Vu+ Box
9-Turn on the VU+ STB
10-Firmware Update will start automatically
11-Wait for the VFD to display "Finished ... please reboot"
12-Unplug the USB Stick from the box
13 Power off the VU+ STB , and restart it again
14-Wait for Image to Reboot
Then follow instruction on the TV screen!
Remember to do Uno upgrade, if U have not
http://www.vuplus-community.net/board/posts/60432/
Have Fun w/BHImages
6-Power off VU+ STB
Have Fun w/BHImages
Thnx a lot a911, I tried it. Didnt work. Copied the files to /vuplus. Bingo, rockn roll. :-)
