YipMan
Hi!3} After you have connected your usb stick, ...............
What is the preferred port for can put my usb?
one above or one below?
thank you
Hi!
thank you
Hi !Format that 8GB on your PC at FAT32. The only limitation will be max. file size - 4GB. It doesn't matter for your needs. If the stick will not work, is not compatible with Solo2. Please, post the model of stick. Thanks.
Hi!If you're using a USB-only for epg, picons, subtitles ??.
then you can use FAT32 PC windows format
and just make a mount without formatting
Then must work.
But FAT32 you cannot use for Multiboot with Meoboot.
thank you a911If U format USB to ext4 (for meoboot) , you still can use it for other stuff!
When U mount USB make the directory >>>>media/usb!
Then install meoboot and other items like picons,plugins, Epg backup,,,etc!
Thanks friend.Format the first partition in FAT32
Remove your USB stick from the box, then format in Fat32 on your pc or laptop, put it back on the box , get your 4 partitions as before then format it using EXT3 instead of EXT4 then mount all your partitions and hopefully you can finally smile. Ps: This is the way I always use to get my USB work properly with: universe and Media/usb( meoboot, picon, swapfile, epg) and it is a 16GB Kingston Data Traveler .Thanks friend.
I already formatted in FAT32
Last night i Hit blue then blue to access Black Hole "speed up" and "enabled" the Opera plug in and hit red for save. The box needed to re boot so I hit ok. Since then it just keeps rebooting continuously never getting past "starting gui" before it tries to boot again.Format that 8GB on your PC at FAT32. The only limitation will be max. file size - 4GB. It doesn't matter for your needs. If the stick will not work, is not compatible with Solo2. Please, post the model of stick. Thanks.
