How to get CAM working with BH
bwa
Hello. I just flashed my Vu+ Ultimo with BH 2.1.7, and did a channel search. Found my channels, and my Canal Digital card is inserted as before, but picture is just back on my channels ?
The Blue Panel states: 1 CAM installed, but still no pictures.
Do I need additional setting ? The SNR on my channel in 88%, so the satelitt setup is fine.
What do I do now ?
/bwa
I don't understand what's illegal with this question. I have a valid and paid for Canal Digital card inserted, so I thougth this was OK ?
Does not Black Hole work with a Canal Digital Card ?
Have you readed the forum rules?
Yes, and this is not a piracy question .... Is it a smartcard reading question, then ? I'm sorry if I don't understand the problem ...
AFAIK, the most tv providers has own proprietary decoders, so the card must work with their own decoders!
Can you please tell me what´s your canal digital provider ( country )? And system coding!
It's Canal Digital in Norway. System Coding ? Have noe clue ... Went from Open Pli where it worked fine from and wanted to try BlackHole, but it seems like a bad idea ....
Haven´t you a proprietary decoder for this card?
I will close this thread as it borders on rule breaking and eventually someone will end up changing the discussion and the the rules will be broken and people will get a ban.
@bwa I understand you just want to get your legitimate card to work and I can assure you there are plenty of forums that can help.
