How to increase event's font
zetamax
Hi guys, I do not know if it's the right place.
Who helps me to increase the font of the event info program (such as the plot of a film) as can be seen from the attached picture.
I managed to increase the written on the various epg (single, multi graphics ...) but this just can not.
Who helps me step by step?
Thank you
You need to edit the skin.xml file of the skin you're using, found at /usr/share/enigma2/"your_skin"
- Connect to the box with a program like FileZilla
- Navigate to the above directory and open the mentioned file with notepad or similar
- Search for screen name="EventView"
- Find there the line with "epg_description"
- Change the font value from 32 to, for example 38
- Save the file, restart gui and see if it's big enough
- Repeat the procedure and find your ideal value with further tries, if not satisfied
- If you can't do any of this, ask nicely Matrix10, the creator of all those great skins, and he'll find a way to help you. :)
You are great :yahoo:and very kind
:thanks:
