how to instal iuu-phoenix usb drivers
rafal1509
hello i try to install this drivers and i am using telnet and this command
depmod -a
update-modules
modprobe iuu-phoenix
i was past iuu-phoenix.ko to lib/modules/3.3.8-2.0/kernel/drivers/usb/serial
and i got this messsage from telnet:
modprobe: can't load module iuu-phoenix (kernel/drivers/usb/seri
al/iuu_phoenix.ko): invalid module format
how to , please help me i try to install my infinity usb unlimited as a card reader
in here you can download drivers original but my one i was copy for some website
http://www.infinityusb.com/default.asp?show=productsdetail&ProductID=11
depmod -a
update-modules
If your reader uses FTDI chipset the drivers are already included. Take a look into Blue Panel -> Kernel driver (or a similr menu) to enable it
i did that , enable ftdi but i cant run infinity usb unlimited :( as a reader , you sure they use ftdi chipset on this programmer
i will try to send email to supplier about chipset , maybe they will tell me , i can give you this to drivers which i already have for supplier website and some other
I'll take a look on the link you have posted above
hello
i got that for the producer ( suppllier) maybe will help next post i will tell you which chipset they use , thanks
https://github.com/jcborras/iuutool
and this
http://www.infinityusb.com/default.asp?show=download&DownloadID=39
Hi Rafal,
Have a look at this tool:
It can be used as an SDK if you wish to do the programming your self.
If you need a COM port for phoenix mode, then you can use this:
Best regards
wb_electronics, Martin Voss
martin@wbe.dk | www.wbelectronics.com
