How to instal navi-x on blackhole xbmc
powel
Can u please advise on how to install navi-x on blackhole. What file should be used, where file should be installed, Can u please be as detailed as u can. thanks
wiered, navi x 0.40 plays live tv channels, but when u want to play move it says getting filter, scarpe, could not open file, any ideas how to solve. Vu Duo2 with blackhole 3.1
Navi X plays films ok on the duo 2....But not live tv as theres no pvr
when i want to play movie in navi-x it says getting filter, scarpe, could not open file, any ideas how to solve. Vu Duo2 with blackhole 3.1, Thanks
It is not a problem due to the image but it is a problem of the plugin itself and the staff that created it (programmers are outside the team BH).
Ask in their site: h@@ps://code.google.com/p/navi-x/
Don't you think that If it was a image problem a mod you have already answered?
There are a couple of fixes for navi x .... one for the sound and one to select the medium player. If you look in the xbmc thread you will find them.
Reinstall the navi x addon then apply the fixes.
