How to install CrossEPG with BH 1.7.8
Deano
Hi. I was using the built-in Rytek-UK but this has stopped working since I upgraded to 1.7.8. I've done some reading and apparently I should use CrossEPG saving to USB. Can anyone please tell me where to find CrossEPG?
Menu >> Setup >> CrossEPG
For CrossEPG you must have HDD or even better USB stick mounted with
Blue button>>Blue>>USB Format Wizard
after USB format you have to mount USB stick /media/usb
with Blue button>>Blue>>Devices Manager>>RED>>/media/usb>>red SAVE
Thanks Matrix, but it's not there - checked in Menu >> Setup and Menu >> Setup >> System but there is no CrossEPG option.
Are you sure that it is not an add-on or anythng? I went through all the available addons but nothing :(
Also, from what you said on the other thread, Menu >> Setup >> System >> Customize >> Setup Mode is set to Expert (always was).
I'm sure. CrossEPG is included by default into BH images.
I do not know what you have installed and how
but CrossEPG is within the image.
