how to install meoboot ?
frh1219
hi
my box : vu dou
image : black hole 3.0.2.F in internal flash
I have hard disk 500 gb on my box
I want install image in harddisk but I cant find meoboot to do it ?
sorry for bad English. I hope that you could understand. thanx
Moderator
hi
my box : vu dou
Now the plugin is called " OpenMultiboot ", and is embedded on image.
Better is using an USB pen drive and you can follow this GUIDE, for implementing it.
This manual is referring OpenBlackHole image, but is the same, for BlackHole 3.0.2F images.
alinet55
hello team
will there be meoboot for 4k vus?why isnt there an option meoboot by which we can copy the settinge of the image on flash?please consider that.
thank you
Moderator
hello team
thank you
Read my post that redirects you to another thread.
Meoboot is now OpenMultiboot.
On the referred guide on my post --> http://www.vuplus-community.net/board/threads/how-to-install-meoboot.29668/#post-215699, you can install and apply to your Vuplus Stb OpenMultiboot.
You can also, by using severall tools ( like Dreamset, DreamboxEdit ... ) copy the existing settings of the image installed in the flash memory to the image running on OpenMultiboot.
