how to mount 2 HDD in vu Solo2
hisham
Hi,
i've 2 HDD, first internal 250GB mounted as hdd, and second external 2TB NTFS that doesn't want to mount it self
i've tried, but when rebooting it is not mounted (tried to mount as video / personal / hdd1 nothing)
any ideas?
thank you in advance
Hi,
any ideas?
also how can i access my external hdd connected to solo2 from my computer without using ftp (filezilla), just using explorer?
Hi
I have the same problem with my external HDD 'my book' 4Tera NTFS, i can't mounted and i can see the files inside!!! you can see and read the files inside your HDD?
Hi
as of now i have transfert all my file to DT in order to format hdd correctly with ext3
