How to mount usb pendrive Vu Solo ?
Marley
I'm trying to mount a pendrive on my solo but I have a problem,
Do I need to format the pendrive linux with my Vu ?
As I'm not sure about it.
That is already written on the forum.
If you want to use a USB stick for EPG, Picon, multiboot etc.
Then you need to format with your box/image
After that mount.
If you have a problem with a USB stick
then you have to find one that works well with your box.
Usually these are older generation USB sticks , do not exceed 4 GB .
After that mount.
Thanks very much for your help Matrix10
Much appreciated
Hi, I'm still confused about using pendrive into my Vu+
After I put the pendrive in it's place (on the back panel of the Vu+ usb port)
Then I went to Devices manager and mount the pendrive with red button
then it seems that have been mount which seems like this
USB USB Flash Memory
Size: 2.023GB Mount:/media/usb
Devise:/dev/sda1
It seems exactly like this on the screen, then when I went to format the usb linux operating system
but when I press the red button to continue then it says that if the usb is already connected to the box you have to unplug it.
How can I format a pendrive if'it's not connected ?
Is there something that I'm missing.
If there is a thread about how to I appreciate any help.
Thanks
