How to play FLV files?
sploits
Hi,
Firstly I would like to say that the black hole image is fantastic. Came from VIX a few weeks ago and never looked back.
The only problem I seem to have is playing FLV files. I could play them on the VIX image but the black hole image doesn't seem to support them (or at least I can't get them to play).
Does the black hole image actually support FLV playback? If so how to I go about doing it?
I just want to be able to pop my USB pen drive into Vu+ Duo and then be able to select them (via media player or something).
Any help would be fantastic.
Thanks,
Sploits :-)
Im never try play this files but i think suport for this was add in last version driver.
Maybe you made update from feed this driver in vix image.
Hi bogdamn,
Thanks for your reply. You mention the VIX image but I'm not using that I'm using the black hole image. How would I update the driver for black hole?
Hi bogdamn,
In the next BH will be included to support to play FLV files as reported by Vu+ Dev team.
VIX img is based on OE2.0 from OpenPLI team and use others programs
OE2.0 can play FLV files , but have many problems with MKV wich can be play like a charm with Blackhole img
