Great this is just the info I was needing could you tell me where I can obtain this plugin at all?You can use something like the UltimeNotizie Plugin to read the rss feeds from BBC News.
Great thanks now got it installed OK. Managed to enter the first feed I require but when I come to the second feed the url is to long to fit into the fill box and it will not scroll allowing me to finish the url line. Is there a way to complete the line in the fill box some how or can I edit a file on my Duo to add feeds through my FTP client? It works very well indeed on my first addition but some urls are longer than the box :-(On the remote control, green button, yellow button, ok, ok, and then scroll down to the plugin.
Sir you are a gentleman I thank you very much for your time and help!!If it goes wrong you can use this one i adjust for you.
unzip and replace.
Hi just another quick question for you could you tell me is it possible in my Plugin list to have this show as " Latest News" instead of "Ultime Notizie" this would really complete my installationYou`re welcome, that`s the meaning of a forum to help each other
Enjoy the plugin.
Thanks
menu, applications, green button, extensions, newsreader
Thanks anyway guys its not that important more that it works which it is.!!Yep you`re right, thought we were in the BlackPole section, what am i doing here then
That`s why i didn`t mention it in the first place, haha
Sorry, forget it
