How to record on USB ?
x30pvr
Dear Mnagers ,
I have done based on following guide , however , I cannot change recording path please help me
thanks
Menu > Setup > Sytem > Customize > Setup Mode: Expert
Then you will be able to select the recording path:
Menu > Setup > Sytem > Recording Path
Yes ,
I did as like this , 2 times blue key then device manager , then mountpoints and then choice /media/usb and system was restarted automatically
and also format is fat32
Thanks
I'm not sure, but I think you have to format your usb stick in Ext3 to use it for recording.
I have check it , however , result was same
The problem is this , I cannot change Recording Path
what is fault ?
Try to mount your usb stick as /media/hdd and create the movie directory on it (/media/hdd/movie).
Yes first , I have mounted it to /media/hdd
then with telnet , I have created movie folder into it
root@vusolo:~# mkdir /media/hdd/movie​
Best Regards
