how to remove plugins
Peter848189
Hi all
I have downloaded a lot of plugins ie (Google maps) and need to remove them can not find a way of removing them.
running 2.05 rev C
Thanks in advance
To uninstall, enter the BH plugin menu, let the list of available plugins be downloaded from the internet, then look at the list and find the plugins which show a blue globe (used as check sign) over them (that means currently installed), highlight the desired one, then press OK to uncheck (->uninstall).
A label on the screen shows you how many packages till now have been queued to be processed.
At the end of your selections, you have to press a button to process the queue of the awaiting operations (install or uninstall) and confirm.
Help I have downloaded the list Blach Hole addons plugins but no blue globes and no way of highlighting them
It's not the addons plugin menu, but:
Menu-> Plugin-> Red button, then let the plugin list be downloaded, then find the plugin to remove.
