How to remove plugins
Palinkat
Hey guys,
Installed some plugins for test, want to remove them now but can't find a way to remove them via the plugins addons panel or in the software management.
For example Damir Subtitle plugin, can't find a way to remove it.
Thanks for your help.
Hey guys,
1.Plugins installed from our image server you can remove with
Green>>Yellow>>Addons Uninstall Panel
2.Plugins installed with Plugins>>Manage extensions or with
Software managment >> Manage extensions
you can remove/delete in the same way you have install them
3.Plugins you have installed manual as IPK file package
you have to look in /usr/lib/opkg/status file
ipk package name and then you can remove package in telnet
command:
ipkg remove package name
example:
in status file we find this for pictureplayer
Package: enigma2-plugin-extensions-pictureplayer
Version: experimental-git20101204-r0
Depends: enigma2
Provides:
Status: install ok installed
Architecture: bm750
Auto-Installed: yes
we can remove with this command in telnet
ipkg remove enigma2-plugin-extensions-pictureplayer
root@bm750:~# ipkg remove enigma2-plugin-extensions-pictureplayer
Removing package enigma2-plugin-extensions-pictureplayer from root...
root@bm750:~#
But beware some packages you must not and can not be erased.
4.and the last option is directly manual delete from the plugins
./usr/lib/enigma2/python/Plugins/Extensions.
When you delete sometimes is not possible to delete everything you have installed
because you do not know all files libs,python that you have installed.
