How to remove recording timer?
Bobik
Some month ago I activated recording timer and used options "from monday to friday". But now I cannot remove this timer. In opti0n menu (timer settings) I've found only to options ("record" and "" switch to channel"). But in both cases timer is still active. How to remove it?
Hi Bobik , I do always as follow: I go to the open webinterface ( 192.xxx.x.x ) from laptop, then go to timers under box control and click to "X" to delete timer (you can also edit or simply disable it)
Hi Ilmago.
It really works. Thanks. But for me it's quite strange. And looks like a bug. I mean if I can set timer by remote I also should remove it by remote. May be Mr. Angelofsky will check this in the future versions.
It works when you set timer and just remove it. But if you set repeated timer (for example from monday till friday) and sometimes recording was done it doesn't work.
