Request How to select a tuner as prefered to record tv channels???
ravedone
Hello mates, I wonder if there is some option in bh image to select a tuner as first choice to record. I can't find the option, I remember an option in openpli, I am not sure. May be it is only posible with open bh...thanks in advance.
I am sorry mates, there is no problem, tested and the dvbt usb tuner select automatically the free tuner to make recordings.
You can set your preferred tuner, under Setup, system, and customise, set the first option to Expert and you should see the tuner options.
Yes, I saw this, but it says prior tuner but not to recordings. I have a double DVB-T usb tuner and the selection is automatic. I have got a vu+ zero. I see the tuner B and C for DVBT and tuner A is DVBS, and they work fine, I thought and looked for the option before trying...I'm sorry. Thank you.
