just do opkg list-installed and find kodi name depending on decoder used (eg. kodi-vusolo2 for solo 2)
type
opkg remove enigma2-plugin-extensions-vuplus-kodi
opkg remove kodi-vusolo2
vuduo2 login: root
root@vuduo2:~# opkg remove enigma2-plugin-extensions-kodi - 1.0-20160331_r0_r0-bh3
No packages removed.
Collected errors:
* print_dependents_warning: Package enigma2-plugin-extensions-kodi is depended upon by packages:
* print_dependents_warning: packagegroup-vuplus-enigma2
* print_dependents_warning: These might cease to work if package enigma2-plugin-extensions-kodi is removed.
* print_dependents_warning: Force removal of this package with --force-depends.
* print_dependents_warning: Force removal of this package and its dependents
* print_dependents_warning: with --force-removal-of-dependent-packages.
root@vuduo2:~#
If you want to remove Kodi because you need more flash space the opkg command must be followed with option --force-depends
If you want PVR clients, they are not avaiable.
