How to upgrade fw VU+ UNO from BH 1.6.6 to BH 1.7.3??
ajdelaguila
Hi!!
I can't upgrade fw versions because of when the deco is booting the 'CH-' message is never shown. I've upgraded succeessfully the FPGA but I don't know how to do it.
Any help will be appreciated :)
Thnx in advanced to everyone!!
Hi!!
If there is attached an usb stick on a rear port of the Uno, try to remove it before to install the new image.
No, there isn't any usb attached on the rear... only an Avermedia Volar Green HD device.
The USB tuner should not influence the image upgrade, but you can try to remove it.
However, I think it's only a problem due to the usb stick you are using to upload the image.
Try to use another usb stick.
Problem fixed.
Because of your indications, Mito, I have reviewed my USB stick settings and the problem was that the primary partition of the stick wasn't marked as 'Active'.
Thnx very much for your help!!
