T tom001 Vu+ User Jul 1, 2015 #1 is it possible to use Hub TV with Open Black Hole? What do i have to do to use it? It don´t start with the red button on my duo2.
Matrix10 Administrator Jul 1, 2015 #2 Not Hub TV but HbbTV , From what I know at the moment does not work in most on Pli-based images , also not in Open BH image. You can use BH image. MyTube TV and HbbTV working.
Matrix10 Administrator Jul 2, 2015 #4 tom001 said: Ohh that´s too bad, but thank you for the information. Click to expand... I believe that HbbTV will be ok in next update.
C cosy Vu+ Newbie Apr 7, 2016 #5 is there a way to install and activate HBBTV on open Blackhole image? Thank you
nunigaia Moderator Apr 7, 2016 #6 cosy said: is there a way to install and activate HBBTV on open Blackhole image? Thank you Click to expand... In Open BlackHole is activated by default, you only have to be positioned on a service that have hbbtv broadcasting. best regards nunigaia
