Howto modify xml file for default skin please?
mebken
Hi,
I want to modify the xml file for default skin in BH1.7.0.
Where Can I found the xml file? I founded 2 files in /usr/share/enigma2: skin.xml and skin_default.xml wich one is to modify.
I want just add the digital time near the analogic time in mini infobar.
Thanks in advance.
Thank you! I will try
Do you have any idea on how to find the mini inforbar screen section (mini infobar = when you press OK once)?
