Howto set EPG button to start CoolTV?
keratos
VU+ Duo
Black Hole 1.7.0
I can start CoolTV if i long press the blue button.
But...
How do i set the EPG button on remote to start CoolTV.
If I press the EPG button, the default Black Hole EPG starts instead of CoolTV
Thanks
Try this plug-in it may have what U desire!
Pauli Neutrino Keymap Plugin
Available @ BH Image server!
I never tested, I like to use easy - info plugin, will try to find it for U and posted here later!
easy info 2
Is a nice and good functional plugin for quick EPG list and Timer list and more,,,!
1- One X (Press) EPG button , will show event info!
2- Twice X EPG button , will show Easy Info list!
3- 3 times X Epg button , will go to Cool TV list!
etc....!
@ Easy Info List U can press menu button to adjust lists for your liking,
Tested and works fine with BH!
Thanx for the author for this fine plug-in!
RgdZ
a911
