HowTo use T2-MIS Channels with BH and OBH
Ev0
Admin
There are several ways you can open these channels with BH and OBH images.
All of them assume you are using BH 3.0.9.B or later, or OBH 4.2 onwards.
T2-MI channels will only work on Vu+ boxes that support MIS (Ultimo4K, Duo4K, Uno4K SE, Uno4K, Zero4K).
1) Important, transcoding MUST be set to use port 8002 otherwise T2-MI channels will not open.
2) In telnet login to your box then type:
opkg install astra-sm
2.1) If using OBH you will also need to go to /etc/astra/ and swap the astra.conf file with the 1 attached to this post.
This will install the required files for T2-MIS channels to work.
3) Reboot your box (not just restart Enigma2).
4) Edit your channel list to include the Zeonbud bouquet attached.
The easiest way to do this, is to open your current channel list in opendbedit, then create a new bouquet called Zeonbud.
When you have done that open a 2nd opendbedit window and open the attached Zeonbud bouquet, select all the channels in the Zeonbud bouquet (ctrl + shift) and then copy (ctrl + c) and paste (ctrl + v) them into your new Zeonbud bouquet in the 1 opendbedit window (right clicking does not give you the copy and paste option).
Then save your channel list.
5 Upload your newly edited channel list to your box.
Alternative way to add the T2-MIS channels.
1) Open your lamedb file with a suitable editor such as crimson edit or notepad++.
2) Near the top of the lamedb file you will transponders listed, scroll down until you see something similar to:
00130000:0007:0003
    s 12524000:30000000:0:1:19:2:0:1:1:0:2
The important bit is the s at the start of the 2nd line (ignore the rest as the numbers are just an example), when you are in this section paste the following into it:
0030b022:0048:0010
    s 12188000:30000000:0:3:48:2:0:1:2:0:2:10:0:1
0030b022:0048:0020
    s 12188000:30000000:0:3:48:2:0:1:2:0:2:20:0:1
0030b022:0048:0030
    s 12341000:30000000:0:3:48:2:0:1:2:0:2:30:0:1
Then scroll down to where it says services
After this paste the following:
0001:0030b022:0048:0010:1:0
12188H MIS 10
p:ZEONBUD,c:001000,f:04
0001:0030b022:0048:0020:1:0
12188H MIS 20
0001:0030b022:0048:0030:1:0
12341H MIS 30
Then save the lamedb file.
Copy the attached userbouquet.dbe00.tv file to /etc/enigma2 then edit your bouquets.tv file.
You need to add this line to the bottom:
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.dbe00.tv" ORDER BY bouquet
Save the file to your desktop.
Then in telnet login to your box again and type:
init 2
this will stop enigma2 so that you can add the new files.
Copy the new bouquet file (userbouquet.dbe00.tv) to /etc/enigma2
Copy the new lamedb file (that you just edited) to /etc/enigma2
Copy the new bouquets.tv file (that you just edited) to /etc/enigma2
Then in telnet again type:
init 3
this will restart Enigma2 and if all is done correctly, you will see your new bouquet with the T2-MIS channels included.
Alternative Option 2:
Open the attached channel list with opendbedit, send them to your box, then go and manually scan all satellites / transponders that you want.
There are other ways to add these channels, but you can not scan them, and the 3 above methods are the easiest.
Thanks a million.
I wrote about it before few days ago.
I'm very excited to try it..
See you soon
Sent from my ONE A2003 using Tapatalk
If someone has problems using telnet and install
astra-sm
it can be installed manually
copy ipk file to / tmp
and
Green Button >> Yellow Button >> Manual Install Ipk Packages
with OK button install ipk file.
(If you use Open Black Hole, it is not necessary to add manually astra.conf it is already in ipk file)
Do not forget
for T2-MI zeonbud you have to edit SAT settings
and add the zeonbud bouquet as it is written in the first post.
The simplest with dreamboxedit as it is written in the first post.
Unfortunately I can't try, I don't have satellite E4.8 .. So far I only have 28, 23, 19, 13 ..
Meyb next month..I'll try do that.
astra-sm
and
Do not forget
Hello.
For astra only need install this ipk? Don't need do nothing more? I want get this channels working in my blackhole image. Today get one backup from another image with this activated, but i don't like that image. I want this in blackhole. Please help me do this. Can some one make step by step please?
I need search channels before? Because i tried search by frequency and find them. But after find channels in manual search they don't be saved in channel list. Help me please. I need this working please.
Please help me people. Now i already have channels in bouquet and can use them but not image or sound and not ***** problem because tried my ***** reader in openatv already configured and work very well. What i need do more for can watch this abertis channels in my favorite blackhole image. Please help me. Please
One more thing, I don't know if this is help but i have downloaded one abertis id.txt file? Where can i put this file? In blackhole image for help me watch this channels?
Hello where can I set the transcoding port 8002 ...!
00130000:0007:0003
0030b022:0048:0010
0030b022:0048:0020
0030b022:0048:0030
12188H MIS 10
12188H MIS 20
12341H MIS 30
init 2
init 3
Thank you it was great
I need a list of T2-MI channels for the following frequencies on the ExpressAM6 53.0E satellite:
DVB-S2
12592 H 14182 3/4
