Request I am not more able to play M3U files on BH3 and VUsolo 4k
Delfino
Hi all, can anyone explain to me why, since last month I can't play my regular M3U files with all the players I use in my VU+ Solo 4k?. I think was some upgrade of release I did, (I installed the last versions of Blackhole to try a repair, but the M3u don't play). I have tried with E2Player, Mediaportal, Kodi, XCplayer, but without success....
With my PC (or with Amazon firestick) the M3U files are perfectly playable..
Can anyone suggest me how to proceed to solve this problem?
Thanks a lot in advance for any suggestions.
Delfino
Delfino
What is the way you are converting the M3U file to play with Vu+ ?
Hi , thanks
I just use puTTY to connect via FTP to my receiver but, perhaps, do you want suggest me any specific command to send to my receiver with puTTy or only suggest me to send the m3u files with it?
Delfino
Hi , thanks
Delfino
Putty is an Open Source ssh and telnet ( command line ) not a FTP tool ( this one for transferring files ).
Try this,
How To Play m3u Files on Enigma2
6 – Enter the username and password: ( user & password = root ), instead only ( user = root ), and for password, if you haven´t set any ... no password is needed ( leave the password field blank and just press enter ).
the latest puTTY
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
Note: There are severall FTP tools ( open source that does what you want ).
  • WinScp
  • Filezilla
  • SmartFtp
I use allways, winscp.
