I dont use Kodi and Transcoding so what do you suggest ?
chulbul
BH Lover
What image is best ? BH tends to take a lot of the flash. I just got the box as the old user moved to solo 4k
Please suggest
Please suggest
With a Duo2? Use the one you want, you have to not be worried with memory problems. ;)
And you can give a try to OpenMultiboot aswell and boot severall images.
wELL i TRIED 3.03E ITS OK AND AS i WROTE when not using any transcoding or HBB or kodi I prefer 2.1.7. The skins for 3.03 are just not great otherwise its a stable image
For skin look to feed and select this whot you prefer
Like what has been fixed ? I still find this the best image. I have it on solo2, uno and Duo2
Its network stable and does not loose fixed IP like the others do. Normal skins can be used. I have no crashes and as I wrote I have no use from transcoding or HBB OR Kodi.
